I'm not quite sure if you're wanting to change your timezone or switch between 12 and 24 hour clocks. Fortunately, the settings for both can be found in your profile settings on the web at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
I wanted standard time not marine time. I did what you said but watch reverted back to marine time. I’ll keep trying. Thanks
