11-30-2020
11:05
17:35
LizzyFitbit
11-30-2020
11:05
17:35
LizzyFitbit
Whenever I try to use Google assistant I get this message on my sense
something went wrong please try again later
It was working just fine then all the sudden stopped. I can still get answers from Alexa and when I try to reply Directly to a text . This is very frustrating and will make or break this watch
Moderator Edit: Clarified subject and updated label
17:45
08:04
12-08-2020
17:45
08:04
Hi @personaltrainer. Welcome to the Community Forums.
Thanks for bringing this to my attention and I'm sorry for the experience that you've had with your Sense. Because you mentioned that the Alexa is working, did you make sure to remove Alexa in order to install Google Assistant? Please note that you can have one voice assistant at a time on your Sense. I'd recommend to verify if your country of residence appears in the supported countries list.
If everything is correct, reboot your phone, restart your watch, allow the Fitbit app to run in the background and try setting up Google Assistant on your Sense one more time. Make sure your phone has internet connection and is within 30 feet of your watch when using a voice assistant.
