11-19-2020 14:52 - last edited on 02-14-2021 11:51 by LizzyFitbit
Hi today a updated my Fitbit sense but we I wanted to install google in the Netherlands it says @ niet beschikbaar in jou regio” ( not available in your region ) wats going wrong 😑
Moderator Edit: Clarified subject, updated label and formatting
11-20-2020 01:32
11-20-2020 01:32
Google Assistant is rolling out to US users at the moment and the press release says:
"Google Assistant coming to Australia, Canada, India, Ireland, New Zealand, Singapore and the United Kingdom in late 2020 in English only; Belgium, Canada (French), Chile, Colombia, France, Germany, Italy, Japan, Mexico, Netherlands, Peru, Spain, Sweden and Switzerland available early 2021."
11-19-2020 15:22
11-19-2020 15:22
Some in Italy
11-19-2020 15:50 - edited 11-19-2020 15:51
I don't think it's available anywhere yet.
11-20-2020 00:29
11-20-2020 00:29
According to the release notes it is suppose to be released with the next firmware.
11-20-2020 01:32
11-20-2020 01:32
11-21-2020 12:03
11-21-2020 12:03
Could you solve the issue if you switch your location to the U.S.? In that case English only, worth a try?
11-25-2020 01:46
11-25-2020 01:46
Is this also true for Alexa? I am using Alexa devices in the Netherlands without problems (in english) so why should it not work on my new sense?
11-25-2020 02:07
11-25-2020 02:07
@Saltheo1 wrote:Is this also true for Alexa? I am using Alexa devices in the Netherlands without problems (in english) so why should it not work on my new sense?
No, Alexa is already launched and also available with audio reply.
But even for Alexa not every country is supported right now. The Netherlands are not listed today:
Voice Assistant on Fitbit Smartwatches
You may switch to the UK to use Alexa in English.
11-25-2020 02:50
11-25-2020 02:50
11-25-2020 03:41 - edited 11-25-2020 03:42
Shame it only looks at your Google accounts region and not the default language. So even if your first language is English, you cannot use GA through Fitbit because you live in the Netherlands? Bit disappointed, as I don't even use GA in Dutch...
11-25-2020 03:45
11-25-2020 03:45
You will have to change your country on your Google Account. This can only be done once a year and will impact any subscriptions you have!
11-25-2020 05:18
11-25-2020 05:18
@Mamamegs wrote:You will have to change your country on your Google Account. This can only be done once a year and will impact any subscriptions you have!
Thanks for sharing!
I would assume it checks two times? When I open my Fitbit voice assistant selection page I can only select Alexa. Google Assistant shows me an information that it is not available in my region. Hence I haven't gave Fitbit my Google account I would assume the first check is the region setting in the Fitbit app. Next check could then be the Google account, right?
11-26-2020 04:05 - edited 11-26-2020 04:05
If you have your location inside the Fitbit app set to the Netherlands, GA will show up as "unavailable". I've my location set to UK, but my Google account is set to the Netherlands because of payment requirements. So GA is available in the app, but when I want to activate it it fails. Even though my language settings for my Google account are set to English. I do not want GA in Dutch though, we are an English-speaking household with several Google appliances, which have no problems with the location/language....
11-26-2020 04:16
11-26-2020 04:16
Stop the presses, I've found a workaround!
Go to Assistant Settings in the Google Home app and change the language to English US. Set your location inside the Fitbit app to US and sync your watch. You should now be able to set up GA. It worked for me!
11-26-2020 04:18
11-26-2020 04:18
Thanks for sharing, @Mamamegs!
