01-14-2025 21:08 - edited 01-14-2025 21:09
In the Fitbit and smartwatch the Google assistant is disconnecting every time I have to reconnect again and again and again by going in the app please get an update or roll-on an update so that this problem can be solved Google and Fitbit please get also solution for this
Best Answer01-15-2025 10:55
01-15-2025 10:55
@Afupro , A warm welcome to the Community! Thank you for your message.
Please make sure that the Fitbit App is allowed to run in the background.
I also suggest you to have a look at this: What should I do if my voice assistant doesn't work on my Fitbit smartwatch?
01-15-2025 10:55
01-15-2025 10:55
