12-29-2022 10:17
12-29-2022 10:17
I'm using the Hawaiian Punch clock face on my Fitbit Sense. Really like the look of this clock face, but...
The screenshots of this clock face in the Gallery app show some options for including the time seconds, not including the time seconds, and including the time seconds with a colon viable. Going into the settings for this clock face there are colour options to chose between, but nothing to change between the time seconds display options shown in the screenshots. How do I get those various time seconds display options on my Sense?
21:31
13:09
12-29-2022
21:31
13:09
Hi @michae1a1ee - I tried the face and it comes with seconds displayed in both 12/24 hr format.
Apart from tapping the face and colour settings there seems no options or description how to use it, Fitbit clocks and apps are often poorly documented.
Trying contacting Fitbit, You can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Best Answer12-30-2022 08:19
12-30-2022 08:19
Guy, Thanks for checking that out and for the response here. I had found the settings to change the colour, but that's it. The fact that there are screenshots on the clock face install page which show different options (seconds showing or not) made me believe it was possible, but I don't see where. I also don't see an option for a 12 vs. 24 hour clock as you mentioned. Not a big deal, but I thought I'd post this to see if I could get an answer to the mystery.
12-30-2022
08:42
13:09
12-30-2022
08:42
13:09
@michae1a1ee- thanks, I agree with you, the screenshots don't match the functionality. Only Fitbit, the authors can help there.
You should be able to change 12/24 hr in the Fitbit App, click profile photo, App settings, if not on your fitbit.com dashboard, should you ever need to change it.
