03-08-2021 10:52
03-08-2021 10:52
Is anyone manning the help hotline. I can’t get anyone to answer it.
Best Answer03-08-2021 12:33
03-08-2021 14:25
03-08-2021 14:25
Best Answer03-08-2021 14:50
03-08-2021 14:50
The more we know of your issue @195635 the better to point you to the right direction. Tell us more so we might be better able to help you.
03-08-2021 15:02
03-08-2021 15:02
Best Answer03-08-2021 20:06
03-08-2021 20:06
Sense controls do nit sync.
First step is to pair the controls to the phone.
Open the phones Bluetooth screen.
On the Sense, swipe to settings - tap and swipe up to Vibration and Audio - tap.
Swipe up to Sense Controls and turn on.
Controls will now be in pairing mode, and in a few seconds, with a refresh it or search on the phone, the controls should show as an available device. Tap and confirm.
You should now be setup.
03-09-2021 03:04
03-09-2021 03:04
03-09-2021 10:47
03-09-2021 10:47
When saying the sense controls will not sync, are you referring to the pairing to the phone?
Or do you mean that you can pair the Sense controls, but they are not able to accept a call.
If you are referring to pairing the controls to the phone. At what step does the failure occur and do you get an error message?
If you can not answer a call, do you get the option on the Sense to answer the call?
There isn't anything to sync when it comes to the Sense controls.
Best Answer03-09-2021 11:14
03-09-2021 11:14
Best Answer03-09-2021 11:42
03-09-2021 11:42
When the watch says waiting to pair.
Tap the sense controls on the phones Bluetooth sceeen.
The two devices should pair or a number should pop up on both the tracker and phone
Best Answer03-09-2021 14:20
03-09-2021 14:20
