06-05-2021
15:36
13:57
LizzyFitbit
06-05-2021
15:36
13:57
LizzyFitbit
I set up a passcode and now I have to put it in several times during the day. I want to use this without having g to use the passcode. How can I disable it?
Best Answer06-06-2021 03:38
06-06-2021 03:38
Hi, @BarbMaxi , welcome, I assume you have set up your device lock as part of your "Wallet" setup. To disable the device lock go to your icon in the top left corner of the today screen of your Fitbit app on your phone>Sense tile>swipe up to and touch Device lock>unlock using your passcode or fingerprint>touch enable for Fitbit Pay only. Return to the previous screen and sync. You will have to enter the code for each payment. If you leave the setting as recommended you will have to use the code every 24 hours or so or if you take off your Sense (which I think is happening now)
I hope this helps.
Cheers
Gr4ndp4 | UK
06-06-2021 03:38
06-06-2021 03:38
I hope this helps.
Cheers
Gr4ndp4 | UK
