10-12-2022
13:12
07:56
10-12-2022
13:12
07:56
I have a Sense and a Versa 3. Can I somehow control both with my Android phone? I can't seem to download a second app.
Best AnswerShort answer, no.
Confused if you are wanting to wear both at same time for separate accounts on same watch, or switch between them on same account, but can't do either.
Best AnswerHi Johnny! Actually I want to wea one for dress and then when I do yard work or other dirty work I would switch to my other watch. But as I see you said I can't. I tried on my own and couldn't figure it out. Thanks for your help. Regards, Bob
Best AnswerYou used to be able to do that. See Can I use more than one Fitbit device with the same account?
But with any recent devices, that is no longer possible. From above article:
It is a much requested ability, but don't hold your breath.
There is one way to do it, but perhaps not worth the trouble.
That way is each time you want to switch, make sure you do a sync to save you data, then stay in same account and do 'Set up a device' to add the other device' which will drop your current device, but data will still accumulate in same account. Then have to go through same process when want to switch back. And if you encounter any issues or delays in setup, such as in getting bluetooth recognized, you might keep re-encountering them.
