11-29-2020 15:29
11-29-2020 15:29
Correcting my time
11-30-2020 00:09
11-30-2020 00:09
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
11-30-2020 00:09
11-30-2020 00:09
