07-21-2021
07:32
14:36
LizzyFitbit
07-21-2021
07:32
14:36
LizzyFitbit
I recently enabled the snore detection on my Sense. My sleep score screen from last night shows Snore Report beside the time sleeping, but I have no way to click on it or find out what the results were. Is this a glitch, or is there something else I should be doing?
10-12-2021
15:30
13:50
KateFitbit
10-12-2021
15:30
13:50
KateFitbit
Hi everyone. @Noggyisms, @MaryLynn53 and @Bisbeesam Thanks for your great help and the details provided. Because this is a public forum, another user might have found that post helpful enough to mark it as the best answer at that moment. However, I understand your point of view and for that reason a different post was selected to help other members.
As you may know, the Snore & Noise Detect is now available to Sense or Versa 3 that have a Premium subscription. Because it'll track noise throughout your sleep period which can last for several hours, you may have to charge your watch more often. You can find more details about this feature in this help article.
To turn on or off this feature on the Fitbit app, tap the Sleep tile > the gear icon at the upper right corner > Detect Snoring. Please note you need to activate the microphone on your Sense to get this feature working. On the other hand, to find your Snore Reports, just open the Fitbit app, tap the sleep tile > Restoration > View Snore & Noise Report.
Hope this helps.
07-21-2021 12:52
07-21-2021 12:52
I woke to the same scenerio. The purple snore report is showing, with sleep score and no data is there when I open it.
07-21-2021 14:13
07-21-2021 14:13
Same issue. I’ve looked and googled and can’t find it
07-22-2021 07:28
07-22-2021 07:28
Woke to the data today, how awesome!! I realized yesterday that I needed to allow the microphone in permissions. I really like this feature, glad FB added it.
07-22-2021 08:05
07-22-2021 08:05
Is this a beta not available to all?
Not finding in apps. Is it compatible with sense.
I’d love to try it but do not know how to enable.
07-22-2021 09:03
07-22-2021 09:03
FYI for those new to it like me, couldn't find it at first, it's located in sleep by opening Restoration.
07-22-2021
09:45
16:50
DavideFitbit
07-22-2021
09:45
16:50
DavideFitbit
Nice,
I will try tonight and confirm if it works on my end. My only option was to add permission when using app. Hope that works. I assume it will show up automatically with the sleep data then yes?
From what I have read, it sounds like it is in testing stages. I didn't have it right away, only as recent as this week.
07-22-2021 10:28
07-22-2021 10:28
Thanks everyone. I didn’t see it but will watch for it. I’d really like to try it!
07-22-2021 10:49
07-22-2021 10:49
@JeremyGirard, I went into apps in my phone settings, found Fitbit, opened "permissions" to allow the FB microphone. Then today my data was in Sleep located by opening Restoration, hth
07-23-2021 05:56
07-23-2021 05:56
@amburd When I go there - my options for microphone are - Only while app is in use, Ask every time, or Deny. No option for allow. Wondering what your options were. I use a Samsung phone too. Tried the Only while app is in use, and it looks like it didn't work for last night.
07-23-2021 10:26 - edited 07-23-2021 10:31
@JeremyGirard, under my phone "Apps" in "Settings", chosing/opening "Fitbit", scrolling down to "Permissions", I open permissions w/choice to allow: calendar, camera, contacts, location, microphone, phone, sms & storage...they are all allowed (for my choice) All I have to do is toggle ea one on or off. Initially, they were all toggled on (allow), except for microphone, I had to allow that one for Snore Score/Report.
07-23-2021
15:18
16:51
DavideFitbit
07-23-2021
15:18
16:51
DavideFitbit
That same scenario drove me nuts for the first few days. Then I tried opening Restoration in the detailed sleep data and there it was.
Perhaps it is in testing stages. Can a moderator confirm? I have a Sense with Premium and I have it (and now that I know how to open it, it works perfectly and is great information.) My husband also has a Sense with Premium and can't find it anywhere? He would like it too - especially since he's the snorer of the two of us and doesn't believe me when I tell him he's snoring.
07-24-2021 00:05 - edited 07-24-2021 11:18
I too would like to know if beta and more details on the rollout. I’d love to have it.
07-24-2021 11:28
07-24-2021 11:28
On the fence now! After using this feature, I like it but I'd now have to charge my Sense every two days using it, not sure it's for me. I hated my Versa over charging every couple days. Day before (afternoon) my Sense was charged 100% & this morning drained & needing charged.
07-25-2021 01:56
07-25-2021 01:56
It's there. Tap a night that has a snore report. Tap the Restoration tile and it's the 3rd section down.
07-25-2021 03:40
07-25-2021 03:40
That good to know. I’m not that excited anymore about getting this feature. Although I will still test it once it hits my app.
07-25-2021
19:29
11:16
JuanJoFitbit
07-25-2021
19:29
11:16
JuanJoFitbit
Thanks! Why do they make it so difficult to find it???😳😂
It’s there, in the app, click on your photo , scroll to:activity and wellness, select sleep, go to bottom and turn it on. Getting the data is confusing to me.
Tomorrow, look at your sleep score. You’ll see a snore bar, select that day, then tap restoration. Your snoring data is there. Thanks to another contributor I was able to find it.
Moderator edit: merged reply
07-26-2021 05:30
07-26-2021 05:30
Still don’t have it yet.
07-26-2021 08:37
07-26-2021 08:37
I agree. Nice feature to see - but not worth the battery drain. Good to check in every once in a while maybe.
07-26-2021 08:39
07-26-2021 08:39
Can confirm that it's working now. Looks like it took a couple of days - wonder if it needed to set something like it did the skin temperature (3 nights). Also good to make sure the snore option is showing on as per GB2020s suggesting below.
