How do I access to the Sense Snore Report?
ANSWERED
I recently enabled the snore detection on my Sense. My sleep score screen from last night shows Snore Report beside the time sleeping, but I have no way to click on it or find out what the results were. Is this a glitch, or is there something else I should be doing?
82 REPLIES 82
Many thanks   Got it!
This is not the best answer. Doesn’t actually answer the OP’s question. @amburd has the best answer which actually answers the query.
His answer isn't even correct though.  Giving the Fitbit App microphone permissions doesn't do anything.  Your phones microphone has nothing to do with sleep sense.  There is a microphone in the Fitbit Sense and Versa 3, the Fitbit device uses that microphone, not the one on your phone.  Quit giving apps permissions they don't need. Quit upvoting bad advice. And if you still think that's the best answer, then why can I use speech to text and google assistant without Fitbit App microphone permissions? Not to mention, Snore report worked without microphone permissions...
I'm sorry but how is this even an answer to the question? This person has obviously got a device that gives a snore report and the Snore report notification is now displayed in his sleep score but when he clicks on the Sleep score there is no snore report. I have the exact same problem. How is your answer the best answer? It answers nothing about where to find the actual snore report that is notified?
Yes it is compatible with the sense but it is only accessible if you subscribe to Premium. Receiving the data, however is an issue. No sign of it yet. I suspect that it may have to go through some processing before it shows up so I will try to be patient. I will also double check to see if my microphone permission is enabled for the Fitbit.
I just verified it is in the restoration report but of course Fitbit has decided not to include any information that would help you find it. Come on, Fitbit! Why do you make it so hard to find these new features that you are promoting?
If you click on the restoration report you will see the snow report inside of it
Make sure your husband has updated the latest version of the Fitbit app as new features often require an update.
Moderator Edit: Merged replies
I have got it working for me now. Thank you
Where do I see the report?
I only see permission and charging questions. Why isn’t it showing that report? It says it is there but when I click I get three metrics. None are snoring.
it has been three days.
Where? Where is it?
Moderator edit: merged reply
Go to #3 Restoration, open it and scroll down. You will find the report
under snore and noise. Hope this helps!
YES!! I’m trying to turn it off because I have to charge my Fitbit every other day vs weekly.
I wish it gave you the ability to hear the clips, so I could determine if I was really snoring or something else.
To see your snore report.  1. Click on the day with the snore report that you want to see. 2. Then click on the restoration section.  3. Scroll down and you will see a place to click the report. 4. Click the report icon.
Thanks for this. The "Best Answer" did not have the actual  instructions for how to find the report details. 🙄  Ended up having to scroll through many replies to find someone who actually answered the specific question that was asked. Yours was the first I saw.
Glad to help!
I am a Premium customer and the report is showing for the last 3 days but I am unable to click on it. How can I access the generated report.
You will have to go into the restoration section within summary for the day to get the report. Not sure why they have it like this but it is how it is!
Thanks much!! 🎯
Same here. Can see the purple report but just get sleep data when I tap it. I shall not be continuing with premium!
How do you see the data? Nothing happens when I tap on the report.
What is Restoration? And where? I see snore report but can't open it.
You have to click on the day and then click again on Restoration. The
report in on the bottom. It's weird
1. Click on the snore report.
2. At that point you will see 3 boxes.
a) time asleep
b) deep and rem sleep
c) Restoration Click on this box. this box contains a
lot of information. first sleeping heart rate, continue down the
page to Snore and Noise. Click on the Snore and Noise
Report. In the restoration box you will also see the
oxygen variation.
Hi everyone. @Noggyisms@MaryLynn53 and @Bisbeesam Thanks for your great help and the details provided. Because this is a public forum, another user might have found that post helpful enough to mark it as the best answer at that moment. However, I understand your point of view and for that reason a different post was selected to help other members.
As you may know, the  Snore & Noise Detect is now available to Sense or Versa 3 that have a Premium subscription. Because it'll track noise throughout your sleep period which can last for several hours, you may have to charge your watch more often. You can find more details about this feature in this help article.
To turn on or off this feature on the Fitbit app, tap the Sleep tile > the gear icon at the upper right corner > Detect Snoring. Please note you need to activate the microphone on your Sense to get this feature working. On the other hand, to find your Snore Reports, just open the Fitbit app, tap the sleep tile > Restoration > View Snore & Noise Report.
Hope this helps.
Thank you @nyarlathjr        I have been trying to locate the snore data since enabling it months ago.  I can't believe it's so hard to find this.
Welcome to the Community, @planginc.
I'm glad the suggestions shared in this thread worked for you, and thanks for your efforts. I understand your point of view about the process to locate your snore reports. Every feedback shared by our members is always welcome as it helps us to work on our features, and improve the experience with them. Your feedback is appreciated and won't go unnoticed.
See you around.
