09-25-2020
03:03
13:11
LizzyFitbit
09-25-2020
03:03
13:11
LizzyFitbit
Just received the Sense but can't find anywhere to add exercise shortcuts. I had this option to add workouts such as spinning and pilates but no matter where I look I can't find this option for the Sense!
09-25-2020 03:12 - edited 09-25-2020 03:23
All options are right on the Sense under Exercise if you tap 'All Exercises'. After you use an exercise type, it goes to the top of the list to be easily found next time, at least for your top 3 choices. You could do short dummy workouts of your top choices to get them to top of list.
Also should note,and I haven't even tried this yet, there's something about double tap on side button bringing up a choice of 4 exercises that you can more quickly start immediately.
09-25-2020 04:05
09-25-2020 04:05
Great thanks for that, I was looking on the app not on the actual watch as that was how I added and sorted with my versa but seen that now on the watch 👍
Best Answer09-25-2020 07:14 - edited 09-25-2020 07:16
@Purplepepper swipe over to settings, then tap shortcuts. Here you can customize press and hold or double press.
The first time the button is held in the user is prompted to setup these options.
06-16-2021 07:25
06-16-2021 07:25
Will this be different if you have premium? I don’t see anywhere where I can add shortcut
