03-21-2022
12:42
11:29
LizzyFitbit
03-21-2022
12:42
11:29
LizzyFitbit
Hello everybody,
I wanted to know if it was possible replace theclock face sense with the clock face Versa 3
which for me is the nicest biggest time
thank's
03-21-2022 21:52 - edited 03-21-2022 22:04
Hi @dexter57 - yes this is possible, in the Fitbit App, click profile photo, device photo, Gallery tile, clocks tab at the top and enter Pleat on the search box and install it.
The Versa 3 and Sense share the same platform so clock faces are normally compatible.
Also look in the Gallery for other Clocks which you might like, you can enter different search criteria.
03-22-2022 04:22 - edited 03-22-2022 04:28
Ciao # ragazzo_
great guy_ !! sorry initially I did not understand the rua answer I succeeded !! thank you very very much
03-22-2022 18:48
03-22-2022 18:48
Hi there, @dexter57. @Guy_ Thanks for your help.
@dexter57 I'm glad you sorted this out and thanks for trying the suggestions shared in this thread. I'm glad @Guy_'s post was of help and I'll mark that post as the Best Answer so it can help other members experiencing the same issue.
If you have time, check out our Health & Wellness board where you can make new friends and find great tips to keep crushing your goals.
