10-05-2023
08:34
08:22
10-05-2023
08:34
08:22
How do I change clockface from the phone? Thank you. (Sense)
Best AnswerThings might be named a little different in the new app, but the basic steps are the same. You can find how to do this with a quick Google search.
1. With your device nearby, in the Fitbit app, tap the Today tab. Devices. your device.
2. Tap Gallery. Clocks tab.
3. Browse the available clock faces. Tap the clock face you want. Install.
Hi @Sergio2022 - if you have a Sense 1, in addition to what @Scott337 says, you can also switch between clock faces already installed by swipe watch face to the left and tap the Clocks app.
If you lightly press and hold the watch clock face it starts the Clocks app as well.
In the mentioned Gallery tile on the phone, Sense tab, you can select between loaded clock faces and also configure them if there is an option.
Often there are operating instructions in the detailed descriptions for 3rd party faces.
