08-02-2022
01:11
14:35
LizzyFitbit
08-02-2022
01:11
14:35
LizzyFitbit
Since holidaying in France all my communications and phone lanuage is in French.
Best AnswerHello @CiaranOR
I hope you enjoyed your vacation 😃 Changing the language on your phone changes the language in the Fitbit app. if the language is only wrong here on the Fitbit Online Community then scroll down to the bottom of the page here. You should see a picture of a globe and the language it’s currently set up as. To change the settings just tap the green down arrow next to the county you want to change then simply select the country you want in the drop down menu. You can also tap dashboard at the top of your screen then tap the small gear icon on the upper left corner of the screen then tap settings in the drop down menu. Now tap personal information and make sure the country you prefer is correct then scroll down and tap submit.
More information can be found here: https://help.fitbit.com/articles/en_US/Help_article/1536.htm
😉Please let me know if this answers your question.
