12-07-2020
15:15
13:09
LizzyFitbit
12-07-2020
15:15
13:09
LizzyFitbit
How can I remove an alarm off the sense? I can only turn on and off, but prefer to delete this specific one. Any help would be appreciated.
Best Answer12-07-2020 15:23
12-07-2020 15:23
Tap the alarm; then scroll down to "Remove".
12-07-2020 15:23
12-07-2020 15:23
12-07-2020 15:29
12-07-2020 15:29
12-08-2020 11:08
12-08-2020 11:08
Scroll all the way to the bottom of the page.
12-08-2020 11:13
12-08-2020 11:13
After you have first tapped/selected the particular alarm you want to delete.
12-08-2020 13:10
12-08-2020 13:10
Best Answer07-16-2021 09:54
07-16-2021 09:54
Thank you so much for this information! I was so confused when I googled it but your instructions were perfect!
10-20-2022 19:13
10-20-2022 19:13
Thanks! I spent too much time looking through Fitbit for this simple answer. Theyh need to work on their instructions.
11-01-2022 12:56
11-01-2022 12:56
Well, that’s a pain! But thank you for the answer. It works!
