01-25-2021
10:39
17:54
LizzyFitbit
01-25-2021
10:39
17:54
LizzyFitbit
When doing sports I have lots of ideas. Alexa and Google Assistant is not activated in my country somehow. Is there any other app I can dictate and it send that to my email inbox for example? Any advice on how to capture all that thoughts on the run? :))
That's great idea! I will try to check if I can automate that with some kind of a software like IFFTT
If you have Android try Macrodroid, its brilliant.
Hello @EugeneBo do you mean from your watch? If Google Assistant/ Alexa don't work (I don't have a Sense/Versa 3 so I can't check) I'm afraid there are no other options as the SDK made available from Fitbit doesn't allow the use of the microphone so it is not possible to develop a purposely made app.
