09-07-2021
17:27
11:28
LizzyFitbit
09-07-2021
17:27
11:28
LizzyFitbit
This actually did not help me. I have 5 clocks saved on the watch but I only did one of them. How do I delete those 4 I do not want so I can add 4 more I do want?
Have a Blessed & Safe Day!
Moderator Edit: Personal info removed and clarified subject
Best Answer09-09-2021 06:58 - edited 09-09-2021 06:59
@Libbytaloca in the fitbit app go to the list of installed faces. Pick the face that you want to remove and remove it. Now choose the face that you want to add.
If you have 5 saved, you can add a 6th face but this one will not be saved on the tracker.
This info may be found in your user manual and the online help.
I moved your post to its own thread, since your question is not about requesting a new feature.
09-12-2021 05:26
09-12-2021 05:26
I have the same concern. I've looked but there is no remove button for three of the factory installed faxes that are simply irritating to me and will not be used, and one literally hurts my eyes. Is there a workaround or will I likely be frustrated and unhappy with my Fitbit?
09-12-2021 10:15
09-12-2021 10:15
Choose the face that you do not want, and replace it with one you like.
Best Answer09-13-2021 12:15
09-13-2021 12:15
Thank you Rich. This worked but I never could find my saved clocks on the app. I finally figured out how to get them after reading between the lines on your response. When I clicked on Clocks I noticed 3 options at the top.
SENSE - CLOCKS - APPS
I clicked on Sense and found my list of downloaded clocks and I was able to delete the ones I did not want. I just needed that push to look a little harder. Thank you so much!
