03-11-2022
03:30
17:11
AndreaFitbit
03-11-2022
03:30
17:11
AndreaFitbit
How do I restart/reboot my Fitbit sense? I’ve not used it in a long time and just need to reboot it so the times/dates are correct and I can start using it again from scratch. Thanks
Moderator edit. updated subject for clarity.
Hi @Laurenherb - you can restart your Sense fully by Shutdown from the watch Settings menu, at the bottom.
Wait at least 10 seconds before placing on the charger to restart and charge it.
Normally it is the syncing that sets the time right but a restart will help the process. If it doesn't work right away try restarting the phone also.
Thanks! I’ll try it now.
