08-10-2021
05:57
07:24
AndreaFitbit
08-10-2021
05:57
07:24
AndreaFitbit
How do I select and delete clock faces
In the Fitbit App
click profile photo
click device photo
click Clocks tile
at the top click on Sense [quite why this is necessary is odd]
On that screen you will then see at the bottom up to 5 mini clock faces installed on your watch
You can click on any of them and then select to make them active
Any that are not selected will have a remove clock face at the bottom if you scroll up
You can't remove the active one.
08-10-2021
12:03
11:16
08-10-2021
12:03
11:16
Are you saying when you click on one of the mini clocks it doesn't change the selected big clock ?
May be try logout and login again of the app.
21:13
11:13
08-10-2021
21:13
11:13
Can you please post a screenshot of the clocks tile screen you see on your phone.
Did you try a logout, or clear cache and force stop of the Fitbit App in phone settings if you have an Android phone?
