05-07-2022 08:18
05-07-2022 08:18
I was trying to set a 2-in-1 interval for my jog/ walk exercise but I couldn't figure out how to do it on the interval setting. Should I do it a different way or will it work in that app.
Best Answer05-07-2022 08:40
05-07-2022 08:40
@Sears4 I apologize if I am misreading your post. It sounds like you want your jog interval twice as long as your walk interval. I can give you an example:
The interval settings are only on the device. They aren't on the mobile app. They appear on the web dashboard, but that is a mistake on Fitbit's part. Interval settings on the web dashboard don't sync with the device.
Laurie | Maryland
