03-19-2021
09:26
05:14
WilsonFitbit
03-19-2021
09:26
05:14
WilsonFitbit
03-19-2021 09:33
03-19-2021 09:33
It is on the Sense itself. From clock face, scroll right through apps to 'Alarms' where you can set, disable, and delete alarms.
03-19-2021 09:33
03-19-2021 09:33
07-21-2022 02:40
07-21-2022 02:40
I can select the time, how do I set it? You can't click on the screen or swipe left or right.
07-21-2022 07:16
07-21-2022 07:16
@Asharples wrote:I can select the time, how do I set it? You can't click on the screen or swipe left or right.
After select the time, at the bottom, click "On". To be sure, after going back to clock face, return to alarms, scroll to that alarm time and make sure it is yellow - on; of it is red with line through it, tap it and get on/off buttons.
