06-15-2021
15:20
11:14
WilsonFitbit
06-15-2021
15:20
11:14
WilsonFitbit
How do I change display to military time?
Moderator edit: subject for clarity/format
You can choose between 12 and 24 hour clock format in your profile settings on the web at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync, your fitbit will be updated.
Hello @Tabbiecat99. Welcome to the community forums! @SteveH Nice to see you around and thanks for your input!
@Tabbiecat99 Adding to the post above, I also recommend reviewing this help article if you encounter any inconvenience:
How do I change the time on my Fitbit device?
Hope this helps.
