Google Assistant routines not working
Thus was working perfectly since I purchased my Sense, but has broken since yesterday. Everything else via google assistant works normally,  but when trying to activate any Google home routines, I get an error, "Routines aren't currently supported on this device."
I tried disabling assistant and setting it up again, but it was of no help.
Does anyone have any suggestions?
7 REPLIES 7
Dude, same here. Thought I was the only one experiencing that. Maybe an update we weren't aware of ?
Still. We need our routines back ... Hope someone here in Fitbit is aware
Thanks for the reply. Good to know that I'm not the only one. Suspect it is an API issue or some sort of permissions setting at the server that is out of sync. Hopefully there is a way to reset this.
Same here. Routines just stopped working.
One more here!
Mine stopped working today!  Hopefully it can get fixed soon!
Mine as well forced to use Alexa. Fitbit get your act together. Do they even monitor these forums?
Is this going to get fixed?
