09-17-2021
10:34
10:52
LizzyFitbit
09-17-2021
10:34
10:52
LizzyFitbit
There appear to be two hot spots on the face of the sense in each of the lower corners. The one on the bottom left changes the display from steps to calories for the face theme I've chosen. Is there a way to set the lower right hot spot to do something - like bring up my agenda?
@ksattler It's good to see you here. @SunsetRunner Thanks for stopping by to help our friend.
@ksattler Thanks for the details provided. May I know the name of the clock face you're using? In case it's a 3rd party clock face, as @SunsetRunner mentioned, I'd also suggest reaching out the developer directly so they can provide you with more details about this clock face and if it can be customized. You'll find their contact details in the clock face description in the Fitbit app.
Hope this helps.
I think these may be a hold out from the Versa, which had 3 buttons and their respective hotspots.
If so, these should start the two left apps on the first apps page.
