09-21-2021 18:58
09-21-2021 18:58
As you can see in the image for the bottom entry my “Zone mins” is significantly higher than the actual time period its for.
Bottom entry: 5:50-9:02 = 192 minutes. Sense says I got 277 zone mins. 277/192 = 1.44 = 44% over estimate.
Middle entry: 9:02 - 9:27 = 25 minutes.
Sense says I got 34 zone mins. 34/27 = 1.25 = 25% over estimate.
On top of that I’m walking in a treadmill and its grossly obviously overcounting my calorie burn compared to what the treadmill says and before you say it yes my profile has accurate information
09-21-2021 23:32
09-21-2021 23:32
Hello @salazarm
Regarding the calculation of the Active Zone Minutes there is no mistake. You can read about it in this article
and specifically the paragraph Why did I earn more Active Zone Minutes than my workout time?
Then there is the problem of the heart rate. It has been reported by practically everybody that Sense is very bad measuring the heart rate with errors, errors that drastically affect calories burned and the same active zone minutes.
09-21-2021 19:08
09-21-2021 19:08
I also have only had it for 5 days now so i doubt its broken or anything…
Best Answer09-21-2021 23:32
09-21-2021 23:32
Hello @salazarm
09-22-2021 10:14
09-22-2021 10:14
@salazarm as @Giampi71 points out, your treating these minutes as Active minutes which these are not.
They are active zone minutes and yes if the activity is intense enough, the user could get more than one minute awarded for each minute.
yes I know I'm being redundant, but others maybe reading this and simply want an answer.
