05-11-2021
11:17
10:59
WilsonFitbit
05-11-2021
11:17
10:59
WilsonFitbit
How do I un-sync my Versa Light, from my iPhone? So I can sync my new Sense? I'm a grandma, so be gentle.
Moderator edit: subject for clarity/format
05-15-2021 11:01
05-15-2021 11:01
Hello @Bubby25. Welcome to the community forums! @Odyssey13 It's great to see you around and thank you for your great input!
@Bubby25 I'm glad you were able to set up your Sense. If the answer provided by @Odyssey13, helped to resolve your inquiry, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
See you around.
05-11-2021 11:22
05-11-2021 11:22
Hello @Bubby25 ! You came to the right place to get some direction. Click this and you'll see the article on how to set up your Sense. Pretty much you'll be setting it up as a new device on an existing account. Be sure to get your Versa Lite out of range of the Sense while setting it up. Usually about twenty five feet or so ought to do it. We're here if you need anything and we like grandmas!
05-12-2021 07:43
05-12-2021 07:43
Thank you! I did it! My grandchildren will be so proud.
05-12-2021 10:27
05-12-2021 10:27
Awesome @Bubby25 ! They should be proud of you! If you have time and want to poke about the forums, click on the link in my signature. We have some areas where people share recipes, tips, tell their stories and there is always something new to learn. Glad you're with us.
05-15-2021 11:01
05-15-2021 11:01
See you around.
