Hello @Tim7894. First, I want to ask if you are using one of the SpO2 clock faces. The SpO2 clock faces are a battery killer and not necessary on the Sense. The Sense has an app called SpO2 tracker. The app description does say you will need more frequent charging, but nothing like the SpO2 clock faces. Your SpO2 will show up as one of your Today stats on the device screen. The SpO2 tracker app doesn't use nearly as much battery as the clock faces. You can uninstall the app by tapping on your profile picture > Sense > keep the toggle on Sense and scroll down to SpO2 Tracker > uninstall.
I hope this helps.
Laurie | Maryland
