08-24-2021
02:45
17:28
AndreaFitbit
08-24-2021
02:45
17:28
AndreaFitbit
does it have weight lifting set count?
or just use exercise app?
Best Answer08-24-2021 09:09
08-24-2021 09:09
Doesn't track reps or sets; just use 'Weights' in exercise app.
If don't see 'Weights', see How do I track my workouts with my Fitbit device?
Best Answer08-24-2021 20:41
08-24-2021 20:41
@Top4718 Unfortunately, while for previous Fitbit OS 4 models there were some third partied developed apps (most notbaly GymGenius) nothing has been developed specifically for Sense / Versa 3 (bases on Fitbit OS 5).
Unfortunately Fitbit made the unpopular decision to break compatibility entirely (something that for example doesn't happen to the much more complex smartphones iOS and Android).
If needed I could find a timer to time rest periods between sets and reps. Bear in mind that if you use Eexercise app to track your total time and GR/calories you can't use this app as Fitbit OS is not capable of multitasking.
