10-20-2023 16:04
10-20-2023 16:04
When I attach my watch to the charger, I can't find where there is an indicator that shows the charge is in process. I have to assume it's charging, but when I leave it for overnight, it's instead all drained. Sometimes it goes to 100% other times to 0.
Best Answer10-20-2023 20:24 - edited 10-20-2023 20:32
Simpleclockpro’s face has a charge rate screen
https://m.youtube.com/watch?v=WlW4ktA7z9o&list=PLCQ6wCl9lWhRtZAjvHY72gWd1_cNTKKmq
https://guytec.com/Fitbit/SimpleClock-Tips.htm
Best Answer10-21-2023 04:02 - edited 10-21-2023 04:09
@flowergirl This section from the Sense manual shows you the screens you will see while your Sense is charging. You should try cleaning your Sense contacts if you are having trouble charging. I clean the back of my Fitbits with alcohol and a very soft toothbrush. I use a cotton tipped applicator dipped in alcohol for the charger. Be VERY careful, so you don't push a pin in. Please look closely at your charging pins. If one looks damaged or pushed in, replace your charging cable. The screen is very obvious when it is charging.
Laurie | Maryland
Best Answer10-23-2023 12:07
10-23-2023 12:07
Best Answer10-23-2023 12:17
10-23-2023 12:17
Thank you for your response, but apparently it doesn't go with Fitbit Sense. I didn't mention that I have the Sense watch.
Best Answer10-23-2023 12:22
10-23-2023 12:22
I meant to say thank you about the information about the screens available while charging. Plus, the correction to the words missing in what I wrote is: What I was hoping to find out....
Best Answer10-24-2023 04:08
10-24-2023 04:08
@flowergirl Yes, you mentioned you use the Sense and my link is from the Sense manual. When you attach the charger, your Sense will vibrate and you'll see your current battery percentage for several seconds. The battery icon has a lightning bolt in it when charging.
Laurie | Maryland
