10-20-2020
03:40
08:31
AlvaroFitbit
10-20-2020
03:40
08:31
AlvaroFitbit
how to remove a clock in fibit sense? ty
Best Answer10-20-2020 04:35
10-20-2020 04:35
@wildcherrii This you can do in the Fitbit app. Start the app, left top - clock on profile and then on Sense under devices. You should now see a set of tiles which include Clock Faces. Under the tab 'my sense' select the clock face you want to remove and then at the bottom you will see the option 'Remove clock face'. Tap on this and confirm.
10-20-2020 04:35
10-20-2020 04:35
10-20-2020 06:35
10-20-2020 06:35
thank you very much.... 😉
Best Answer11-12-2021 10:21
11-12-2021 10:21
Works on other clock faces I've chosen but not the Guilloche. The red, "remove clock face does not appear. Any other suggestions? The face removed the date and gives me heart rate twice.
02-03-2022 09:51
02-03-2022 09:51
I have the same issue, Do not see "Remove clock face" in my app.
Best Answer02-03-2022 09:54 - edited 02-03-2022 10:23
@BradleyJ "Remove clock face" should show up on a clock face that isn't the ones currently selected.
Best Answer02-03-2022 17:44
02-03-2022 17:44
Thanks eezeepee, With your answer, "I thought I needed to highlight the one to delete" and along with Guy_'s answer help me beat this delete and add thing.
Guy_'s answer following for those in need.
In Android phone Settings *
Apps
Fitbit
Storage - clear cache [not data]
Force Fitbit shutdown
[though it doesn't seem to fully]
Log back in to the Fitbit app
02-04-2022 11:04
02-04-2022 11:04
02-04-2022 11:06
02-04-2022 11:06
I should add these are the steps on an iPhone app 🙂
Best Answer02-04-2022 13:10
02-04-2022 13:10
You won't see remove clock face for the active clock face, you can only remove the other ones, this is to avoid having no clock faces.
05-07-2022 22:04
05-07-2022 22:04
Works on all my clock faces except Hamilton Analog by Gordon Wallace which does not have a Remove Clock Face button! Cannot get rid of it. Sooo annoying
22:21
10:53
05-07-2022
22:21
10:53
Best Answer05-08-2022 00:13
05-08-2022 00:13
Thanks, missed that. Should be in the manual
05-08-2022 18:27
05-08-2022 18:27
I need to set up my watch but I couldn't make it
Best Answer11-07-2022 17:15
11-07-2022 17:15
Thank you. I searched for hours and then found your answer. Worked perfectly…clock face deleted.
