09-28-2020
23:55
15:35
LizzyFitbit
09-28-2020
23:55
15:35
LizzyFitbit
Hi network
Can anyone help me figure out how I can transfer my activity data to google fit?
Thanks in advance 🙂
Regards,
Faraz
09-29-2020 17:09
09-29-2020 17:09
You can transfer your Fitbit info to your Google fit via 3rd part app called Fittofit (android). Go to the Google Play store and download it. The app will ask you to login/set up the transfer on both apps. And there you go. You can do a manual data transfer anytime but it does an auto at 12 am. I have been using Fittofit for over 2 years now and it works well. I hope this helps.
09-29-2020 15:57
09-29-2020 15:57
Hi @farazehjaz. It's nice to see you here in the Community Forums.
Thanks for your question about transferring your data to Google Fit. Let me explain that currently it's not possible to integrate Fitbit with Google Fit. I understand how helpful it's to track your progress on both accounts and our team is constantly working on our products and services to enhance the Fitbit experience based on our members feedback. I also found this idea posted by another team member in the Feature Suggestions board. While it's listed as Not Currently Planned, please add your vote to show your support. You can also get in touch with Google Fit team so they can work on an integration with Fitbit using our open API.
If you need anything else, feel free to let me know.
09-29-2020 17:09
09-29-2020 17:09
10-01-2020 10:03 - edited 10-02-2020 08:58
Thank you Hadden8176 for the advice regarding the Fittofit App. I installed the App on my Android phone and logged into both Apps. I tried a manual transfer and even though the Fittofit Apps indicates the data transfer was successful, the Google Fit Apps indicates less than 5% of my total steps per the Fitbit App.
Am I missing something?
**UPDATE**
October 2, 2020 - I read a post by the creator of the Fitofit App, in that post he recommended that you NOT use your Google account to log into Fitbit (which I had done). I changed my login to email/password (Non-Google) and a short while later the data was syncing and appearing correctly in the Google Fit App.
Problem Solved!!
Best Answer10-02-2020 16:51
10-02-2020 16:51
Hi @Hadden8176, it's nice to have you around. @GreyWullf52. Welcome on board!
@Hadden8176, thanks for stopping by to help other members. You shared a great suggestion and I'm sure others will find it very helpful when trying to get their data synced to Google Fit. You're a star!
@GreyWullf52, thanks for joining this thread and sharing the steps that worked for you. I'm glad that you were able to get your Fitbit data to Google Fit and I hope you enjoy the Fitbit experience.
Don't hesitate to let me know if you need anything else from me. 😎
Best Answer10-02-2020 17:22
10-02-2020 17:22
@LizzyFitbit I'm trying to be a team player. I like helping!!!!!
