03-02-2021
00:11
10:53
WilsonFitbit
03-02-2021
00:11
10:53
WilsonFitbit
I got a new Fitbit sense and I can only decline calls and am unable to awnser them, I also can't reply to texts, also is it meant to need sinking every day? Please help me
Best Answer03-02-2021 04:58
03-02-2021 04:58
Hi @Itisnotworkinh - welcome to the Community forum!
Hope this helps. If not, please let us know.
Best Answer03-02-2021 08:15
03-02-2021 08:15
In addition have you setup Sense Controls? We are assuming you do not have the option to answer calls.
Is your mic turned on?
Maybe you do have the option to answer a call and it doesn't work. Using the phrase "I can't" doesn't really help us in determining what is not happening.
When you say you can not reply to texts, are you referring to reply with voice? Can you do a quick reply?
03-03-2021 00:58
03-03-2021 00:58
