04-18-2021
03:08
07:34
WilsonFitbit
04-18-2021
03:08
07:34
WilsonFitbit
I cant seem to adjust the sleep sensitivity on my Fitbit sence?
In the sleep section there are no further setting so it's not show all the time inwake up but showing my moving around in bed as steps?.
04-18-2021 10:16
04-18-2021 10:16
Hi, @Minky1510, the setting you are looking for is on the online dashboard. Click the gear wheel in the top right corner>settings>scroll down to "Sleep Sensitivity" and select normal/sensitive. Return to the dashboard page & sync the app on your phone. You may find this article useful How do I track my sleep with my Fitbit device? You probably know that the device interprets arm movement as "steps", a restless nights sleep does get you some steps but not that many. How does my Fitbit device calculate my daily activity? explains in more detail.
I hope this helps.
Cheers
Gr4ndp4 | UK
