08-16-2021 08:17
08-16-2021 08:17
TL;DR display movement notifications (those ones like "do a few steps" you configure in the app) the same way as phone notifications - with short screen on time
Explanation:
A smartwatch is a way to quickly decide which priority a notification belongs to, that's the case with every notification a smartwatch does...
So the "move your body a bit" notification should be the same way than the ones from the phone, to be able to decide which current priority moving the own body currently is...
At the moment those notifications are without display, just a short vibration on the wrist, which rather confuses whether I missed a phone notification or not...
So - all notifications from the watch should be treated like phone notifications unless the user decides to not vibrate, to vibrate using a different vibration-pattern or to not turn on the display for that notification.
(done with a Sense, but I expect it to be the same on every Fitbit that does those movement-notifications)
Best Answer08-18-2021 18:13
08-18-2021 18:13
Hi @paradonym ,
A warm welcome to the Community!
Thanks for your suggestion. We're constantly striving to improve Fitbit products and services, and we appreciate all of the input we receive from our customers. The best place to make your voice heard is the Feature Suggestion board on our community (community.fitbit.com/t5/Feature-Requests/idb-p/features).
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
Thanks for your feedback and for participating in our community!
