09-06-2022
12:24
12:09
LizzyFitbit
09-06-2022
12:24
12:09
LizzyFitbit
I just ordered the Sense 2. Will it have the same band as the original Sense?
Best Answer09-06-2022 12:44
09-06-2022 12:44
@BBBird It looks like it is the same infinity band. The bands are interchangeable between devices. Some users posted about band irritation from the Sense and Versa 3 bands. If this is your concern, I can't find any documentation that the band is made from a different material.
Laurie | Maryland
Best Answer10-18-2022 21:21
10-18-2022 21:21
Thank you for the answer.
I have a same curiosity as well, but the band of sense 2 is so comfortable to wear. It will be nice to know what material is @fitbitsupport
Best Answer11-12-2022 17:00
11-12-2022 17:00
I got replacement sense strap before I ordered the sense 2 watch. The straps looked the same so thought it was no problem. Got the watch today and set it up. Only to change it to the straps I ordered and it didn't click into place. Very sad as I thought I had everything sorted
12-26-2022 04:41
12-26-2022 04:41
I have had the same problem had about 5 straps from.my sense and found none of the metal straps are compatible only the plastic ones.
02-15-2023 09:13
02-15-2023 09:13
My Sense bands do not fit my new Sense 2. Both ends go in but only one will click and be secure.
02-15-2023 16:58
02-15-2023 16:58
Is it possible they are non Fitbit bands and not to specification. In which case they may not fit a Sense either.
The bands made by Fitbit normally list both models. See this metallic example
Best Answer03-07-2023 10:25
03-07-2023 10:25
These bands are not interchangeable. I upgraded from the sense to sense 2 and my bands that I had been using with my sense did not fit my sense 2.
03-07-2023 10:58
03-07-2023 10:58
Hi @DarkSpirit - were they official Fitbit bands?
Best Answer03-07-2023 20:48
03-07-2023 20:48
Nope. Lots of stuff says they are interchangeable but if you read you will see that only one side will fit and be secure.
It's a bummer for sure.
j
Best Answer03-08-2023 08:12
03-08-2023 08:12
In fairness all of the bands I had they were not fitbit branded. However the link you posted is useful but very limited on styles and colours and I wonder if this is something fitbit/other vendors could take on board. So far I am.limited to only my plastic straps. Would be great to see new styles. (I am hopeful ☺️)
Best Answer03-09-2023 00:47
03-09-2023 00:47
Best Answer03-21-2023 18:56 - edited 03-21-2023 18:57
Now some time has passed, there's starting to be infinity/nylon/elastic bands being made and available for the sense 2 now. I've recently got a few different bands. I got mine off Amazon
