10-13-2020 04:09 - edited 10-13-2020 04:10
Just received my Sense. I've often gotten somewhere on the Sense and wished to go back. Is that feature available like on my Android phone? My only solution so far is to activate side button.
10-13-2020 05:02
10-13-2020 05:02
The side button will generally take you all the way back to the clock. If you just want to go back a screen then swipe from left to right on the screen, making sure you start with your finger on the left edge of the frame.
10-13-2020 05:02
10-13-2020 05:02
10-16-2020 22:30 - edited 10-16-2020 22:31
Hi Steve
I have a Versa Fitbit but I need to reset the clock any ideas on how I can do this please?
Best Answer10-17-2020 00:06
10-17-2020 00:06
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
10-17-2020 00:47
10-17-2020 00:47
Best Answer06-24-2021 11:43
06-24-2021 11:43
Thank you, I received today, and was like how am I supposed to go back. Life saver
