Just had to bite the bullet on my Ionic with the product recall. Frustrating as my Ionic was still working perfectly and I never had any issue with overheating (my wife did on hers)
One of the functions I grew to very much rely on was a feature on the clock face I was using, RedStats by Loic Pelletan, whereby if you tap the screen three times in succession it would turn white and could be used as a really handy flashlight. Just bright enough to see in the dark but not blinding like a smartphone torch - perfect for night feeds and checking on waking/sleeping kids.
Is such a function possible on the Sense, and if so where can it be found? I know there are probably flashlight apps, but I'd prefer not to have to scroll through apps to access what could be a simple function.
Thanks Guy,
Great to see developers putting so much thought into the functionality of their clock faces. Searching through descriptions on the gallery can be tedious work so I really appreciate the recommendation, I'll check it out when my new watch arrives.
@yodellinhank - yes the gallery has been very successful and now there are many items and it's difficult to refine a search.
See an example for the flashlight on the battery status screen
SimpleClockPro charging info
I use the flashlight nightly to maneuver through the bedroom to the bathroom. Works great
