12-11-2020 04:43
12-11-2020 04:43
Is anyone having issues lately with Fitbit Sense not getting any notifications. I have done everything re-installed the app, setup my sense again. The notifications show on my phone but never make it to my watch, it just happened all of a sudden yesterday. Any suggestions.
12-11-2020 04:45
12-11-2020 04:45
I seem to have the opposite... i get notifications for blooming everything... and need to find the time to turn certain ones off. 😂
Best Answer12-11-2020 08:46
12-11-2020 08:46
I just contacted customer service to help me with it. apparently I need help from a specialist and who knows when someone will contact me.
12-11-2020 08:49
12-11-2020 08:49
it seems to be if you have your phone on silent then it doesn't get the notification. where it wasn't an issue before as my phone was always on silent. if you put your ringer on or on vibrate them come through. I am on the android platform as well, not sure if that makes a difference.
Best Answer12-11-2020 10:12
12-11-2020 10:12
Yes if the phone is on silent, the phone doesn't send notifications to the lock screen and no notifications will show up on the Fitbit.
If notifications are setup and all permissions have been given. I find a restart or a shutdown of the phone or helps.
Worse case I disable notifications, or log out of the app. When enabling notifications or logging in, I am required to renew the app permissions.
Best Answer12-11-2020 10:17
12-11-2020 10:17
Best Answer12-12-2020 09:14
12-12-2020 09:14
We are still waiting to find out what phone you have been requesting help for.
If your phone is doing everything right. Is the tracker on its DND or Sleep mode?
BTW we do not know what has been tried or if you see any error messages.
Best Answer12-12-2020 09:20
12-12-2020 09:20
Best Answer12-12-2020 09:43
12-12-2020 09:43
A phone or Fitbit app update may revoke access. Have you checked permissions, Turns off notifications then turned on? Logged out of the Fitbit app / logged in?
Either option will force the app to renew permissions.
Is power management still disabled for the Fitbit app?
Best Answer12-12-2020 09:53
12-12-2020 09:53
Best Answer12-13-2020 02:07
12-13-2020 02:07
I have the opposite happen - sorry to be awkward lol.
I have my phone on silent all day at work - and I'm still receiving notifications on the Fitbit.
Best Answer12-13-2020 03:11
12-13-2020 03:11
Best Answer12-13-2020 03:19
12-13-2020 03:19
Sense User:
Exact same thing happened to me when I woke up this morning, no smart notifications. Only normal calls were coming through. On one of the forums for versa I read that for Android phones if you go to Settings > Apps > Fitbit and then clear all cache as well as storage, it resets the whole thing. Your data will not be lost, just that you will have to log in to your account on the app again and set things the way you had before (cumbersome, yes) but worked.
I am not able to get WhatsApp CALL notifications though. Any idea why?
Best Answer12-13-2020 03:28
12-13-2020 03:28
