01-30-2022 05:15
01-30-2022 05:15
After 2 months I have a key pad show up as I try to swipe. Looks like they want a password. Entered one nothing happened. Any ideas?
Best Answer01-30-2022 05:32
01-30-2022 05:32
That is probably the 'Wallet' app wanting your PIN for Fitbit Pay. Sounds you went to that app. Do you have it set up? If not, press side button to get out. Check your shortcuts in 'Settings' if you have Wallet set as a shortcut but don't want it.
