How do I stop my Laptop from making the charging noise like when I first plug my Sense into the USB?
I called Fitbit and they heard the noise and advised I restart my Laptop but that did not help.
It's a four note notification that keeps repeating. Any suggestions welcome!
Best AnswerOnly suggestion is to look for some hidden dialog box waiting for you to answer a question.
From "4 note notification" description, I assume it is not fan.
@rrubin Welcome to the Ftibit community.
Along with @JohnnyRow suggestion, you should really charge your Sense with an actual USB charging block. Most computer USBs are very low in amperage.
21:12
11:04
The magnet is not a moving field and should not be a problem.
Your laptop will only supply an half an amp, while the tracker can handle an amp. I would be using the phones charger.
Then again, the noise could be coming from a componant that is about to fail.
