02-05-2025
17:58
09:56
DavidFitbit
02-05-2025
17:58
09:56
DavidFitbit
I did contact Fit bit support...
they walked me through all kinds of trying to reset the fitbit...and after trying 10 different things ..they basically said...SORRY..we can't help fix the problem we caused...and since your product is out of warranty and see suck at owning something WE CAUSED ... you are screwed..However we will give you 35% off of purchasing a new one (in the good old days' companies would replace defects caused by them.)
so what I did is let it completely let it drain...
I completely removed the app.
I recharged the Fitbit...
I got a red X saying it could not sync
I reinstalled the Fitbit app ...it came on...I syned it... I'm good.
Google now owns fitbit...I think I saw were they are Not going to make any more (usually happens when one company buys another...they assimilate the good bit and throw out the original)
THis is my last fitbit... I've owned one since they had the clip on model.
will be looking for a better replacement when this really dies.
Similar problem here. Mine's not completely dead but no text is showing, making entertaining the PIN almost impossible. Most of the menu options are just blank spaces. I remembered the exact location of the restart option so I scrolled through the blank spaces and restarted the watch, but that didn't work. The watch is basically unusable now
Hi @Vswindell, @Pamfootsteps and @PCsurgeon, Thank you four your responses.
I'm glad to help update your Fitbit device.
Occasionally a firmware update will start and stop or otherwise fail. Considering the description of your issues, i would suggest to follow the instructions listed in our help article Why can't I update my Fitbit device? below the section "Sense series and Versa series".
If you are still unable to make your device work even after these steps, you can do just like @Pamfootsteps did and contact our support team for further investigation.
The count with better resources to research in depth.
Best AnswerI did contact Fit bit support...
