01-16-2022
10:49
10:58
EstuardoFitbit
01-16-2022
10:49
10:58
EstuardoFitbit
It is all to easy to accidentally pause or even close the tracking of an revise and not notice it has happened. The Sense seems to be particular vulnerable to this. What can cause those? A coat sleeve or gloves, even the action of clapping your hands, it can stop the exercise tracking and is very unsatisfactory.
A solution is needed to prevent this such as a PIN enabled lock of the physical button and the screen buttons to close or pause the exercise.
Best AnswerAll of this just to find how to change my weather on the watch from C* to F* - despite settings in my Fitbit app being selected for Fahrenheit already. I had to finally find a random weather app that did not have a check mark saying installed, only to find it was installed, and then configure it.
Fitbit developers - what the hell guys?? This is TERRIBLE.
01-16-2022
11:56
04:10
01-16-2022
11:56
04:10
@error4o4 Welcome to the Community Forums.
Thanks for taking the time to share your feedback about the Fitbit app, I'm sorry for this inconvenience. Our team constantly works on our products, services and overall Fitbit experience, and feedback like yours will definitely helps us to improve them.
Before anything else, let me explain that our team consolidated the App and Clock Faces sections to one called "Gallery". Once you tap on it, under Sense you'll find the clock faces and apps already installed. On the other hand, if you tap on Clocks or Apps you'll find the rest of the gallery so you can install anything that you'd like to have on your watch.
Because Weather is a separated app from the Skin Temperature tile, they'll have their own settings so you can adjust them depending on your preference. To adjust the units for the Weather app, please open the Fitbit app, tap your profile picture > Sense > Gallery. Then scroll down, tap Weather > Settings and make your changes. To adjust the Skin Temperature tile, follow the instructions described here.
