07-23-2025
13:32
17:21
ManuFitbit
07-23-2025
13:32
17:21
ManuFitbit
Why do i all of a sudden keep having to log into the app to see my steps etc? It used to stay logged in.
Moderator edit: clarified subject.
12 hours ago
12 hours ago
Hi @Jill2022 - normally clock faces show your steps but if you have one that doesn't try changing to one that does.
Also swipe the watch face to the right to get to Quick Setting and make sure Sleep is not enabled and Wrist Wake is, so that the watch display comes on automatically when you look at it, displaying all the information you have chosen.
Even so if you double tap it the display will come on and you should also be able to swipe up, and if configured, it will show your steps in Core stats, though an appropriate clock face is the best choice.
