09-23-2022 05:41
09-23-2022 05:41
I used to get email notifications when my Sense battery hit 25%, but all of a sudden, that stopped. I have reset my watch. I have turned notifications off and on in the Android app. I have turned notifications off and on in the web interface. Nothing works any longer.
09-23-2022 10:27
09-23-2022 10:27
Hi, @jon_bondy , welcome to the community. The setting you need to check out is from the today screen touch your logo in the top left corner>notifications>slide up to email notifications"low battery" and set the slider to the "on" position. Return to the today screen and sync.
I hope this helps.
Cheers
Gr4ndp4 | UK
09-23-2022 12:29
09-23-2022 12:29
@Gr4ndp4As I said in my description, I've done this more than once, but I did it again just now. I'll let you know how it goes.
09-24-2022 04:52
09-24-2022 04:52
I have always had my notifications on for low battery and I’m still not getting any.
09-24-2022 04:52
09-24-2022 04:52
Same for me.
09-24-2022 05:27
09-24-2022 05:27
I noticed that, too. No email notifications about low battery anymore. Now battery is 14% and I haven't received any email notification. Last notification came on 13 September and since then I had to recharge it three times (under 15% of battery) but no notification happened.
09-24-2022 08:23
09-24-2022 08:23
I love Fitbit and have had many of the styles over the years. However, I e noticed how communication from the cI ox my is not as good as it used to be. I was able to call and talk to someone in the past. It’s disappointing.
09-28-2022 06:19
09-28-2022 06:19
@Gr4ndp4As I expected, your suggestion did nothing to help me. I continue to have the FitBit go below 25% charge without receiving an email notification, even though I was getting them up until recently.
Is there any way to complain directly to FitBit to fix this bug?!?
11-14-2022 18:25
11-14-2022 18:25
Does anyone know of a way to contact FitBit support? I just took a survey which implied that this is possible, but I can't find any way to do this. I suppose that is one way to keep people from complaining.
11-14-2022 21:51
11-14-2022 21:51
Hi, @jon_bondy, contact "Customer Support" using the chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
