04-03-2021 20:55
04-03-2021 20:55
I have a new sense, I've set it up to receive fb messenger notifications and I got it to work... Once. Not again. I receive emails only. I had the same problem with versa 2, I've followed all suggestions so far to no avail. My phone is Huawei Nova 2i.
Best Answer04-06-2021 07:52
04-06-2021 07:52
Hi @Traceytheshire,
have you tried the settings beneath:
To reliably receive notifications on the Huawei P30 Pro and to be able to synchronize reliably, you should proceed as follows:
Turn off power consumption warning: Settings - > Apps - > Apps - > Fitbit - > Power Usage Details, then disable the power usage warning there.
Manual start: Settings -> search for app start and then search for Fitbit. There on manual and activate all three options for Fitbit.
I use a Huawei P30 Pro and a Sense (previously Ionic). It works flawlessly with these settings together.
Sorry for the screenshots in foreign language but the screens should look the same except the wording.
Good luck!
