05-10-2021 09:22
05-10-2021 09:22
My Sense will not charge , or turn on. No lights. Think it is completely dead!!
05-11-2021 00:33
05-11-2021 00:33
There are known problems with chargers - check the 4 pins are equally prominent.
Have a look at the suggestion posted here it may help isolate the cause.
And also Why isn't my Fitbit device's battery charging?
If that fails try Fitbit Support. They may be able to help you with a replacement as its still under warranty.
05-11-2021 00:33
05-11-2021 00:33
05-24-2022 22:45
05-24-2022 22:45
Their support is worthless!
05-24-2022 23:04
05-24-2022 23:04
Hi @btwasem - this might help.
How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
12-28-2022 09:53
12-28-2022 09:53
Same issue. New charger, etc. Dead as a door nail. My Sense is not that old! Very disappointing.
12-28-2022 09:53
12-28-2022 09:53
12-28-2022
10:46
13:21
12-28-2022
10:46
13:21
Hi @SunsetRunner - have you checked the new charger, cleaned the terminals on the back of the watch as described and used a PC as power source?
Sometimes the watch doesn't start when charging and has to be started with the button. If neither are working did the watch get wet at some point? Or stop suddenly?
12-28-2022 12:30
12-28-2022 12:30
12-28-2022
12:35
13:19
12-28-2022
12:35
13:19
@SunsetRunner - can you chat via the Fitbit App, click profile photo, Help & support, Contact Customer support, to make sure there is a fault.
If so, take it back to where you bought it for replacement under warranty.
12-28-2022 15:40
12-28-2022 15:40
12-29-2022 05:21
12-29-2022 05:21
Clean watch and charger with rubbing alcohol before charging. It works for me every time.
12-29-2022
07:00
11:14
LizzyFitbit
12-29-2022
07:00
11:14
LizzyFitbit
Thank you and I have done this, even with the new charger. Fitbit helped
me out and is sending me a replacement. Fingers crossed!
*Kindest regards,
Moderator Edit: Formatting
