11-12-2020
16:26
10:37
EstuardoFitbit
11-12-2020
16:26
10:37
EstuardoFitbit
My Sense is not receiving any of my notifications. I have tried the test call, it doesn't vibrate. I have shut it down. Unpaired and repaired it. I miss having my notifications at my wrist. Help!
Best Answer11-12-2020 19:24
11-12-2020 19:24
Your sense needs to be paired to the Bluetooth of your unknown phone for notifications to be sent @Kylee-H.
First check the quick settings to see if sleep or DND is not enabled.
I would check your settings.
Yes you can unpair the tracker from the phones Bluetooth. This will only hurt a sync issue, and the user will not be able to repair the tracker to Bluetooth.
