12-20-2023
16:36
07:22
12-20-2023
16:36
07:22
Several days ago I realized my Sence wasn't charging properly. I was using the official charger, changed outlets several times and no luck. No luck getting to the chat feature on the app. Several attempts later I managed to get on a chat on the website.
Hi @Drdrfl - this isn't necessarily a terminal fault.
Have you tried replacing the charge cable to make sure it charges.
Then turn off the phone's Bluetooth and restart the watch again.
Then try resyncing and if unsuccessful remove both Bluetooth entries from the phone and run set up a device in the Fitbit App, lastly if still an issue remove the watch from the Fitbit account and Bluetooth and then run the set-up again.
Make sure there are no other watches or phones or devices running the Fitbit App switched on.
Hi there, @Drdrfl. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that your Sense is still not working despite all the steps you have tried so far. We‘re taking your comments and sentiments in regards to our products and services into consideration. @Guy_ Thank you so much for trying to help!
Please note that our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can. For more information about our warranty, see fitbit.com/legal/returns-and-warranty
Even though I truly appreciate that you've taken the time to come here and share your experience, please note for this kind of inquiries/cases/process, there's no so much we here in the forums can do for you as this is something that our Support Team handles based on our policies. Nevertheless, please feel free to reach out to them again if you need further assistance or clarification regarding the outcome of your case.
Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly. They will tell you what's next!
