06-28-2021 05:36
06-28-2021 05:36
I have lost all other screens other than the home screen. All I get is the calculator when I swipe any direction. Is it something simple that I'm not doing. I have only had the watch for 6 days.
Best Answer06-28-2021 07:33
06-28-2021 07:33
Sorted! It turns out I'd somehow set a pin number to always, instead of when using wallet. Went into the app and changed it back and now it's all good!
06-28-2021 07:34
06-28-2021 07:34
Hi @Dibdeb let's open the fitbit app on the phone.
Tap your profile picture.
Tap the Sense.
Now let's tap the Apps Tile.
Does the list show all the apps that you should be seeing?
If so then let's add an app by tapping Show All Apps.
Choose an app you would like or any app. I believe this will force the Fitbit App to reload your missing apps. You can, if want, remove the app you installed.
Best Answer06-28-2021 07:38
06-28-2021 07:38
Thanks Rich for your response. As you'll see above, I managed to sort it out myself. I was just being a bit dim. 🙂
